ISDN Issue
Hi Guys,
I have a Cisco 3640 and would like to use it as a ISDN/PRI gateway, to receive PBX connections.
My problem is I cannot enable pri-group on it, the command is not available on controller level.
According the hardware below is that possible or should I order additional hardware.
Here is the hardware/Software I have:
1 NM-1FE2W
2 2MFT-E1
IOS 12.2(2)XT3
My show version output:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(2)
E SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 13-Mar-02 23:16 by shawnk
Image text-base: 0x600089A8, data-base: 0x6155A000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
ROM: 3600 Software (C3640-IS-M), Version 12.2(2)XT3, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
r3640.sp.01 uptime is 5 days, 6 hours, 13 minutes
System image file is "flash:c3640-is-mz.122-2.XT3.bin"
cisco 3640 (R4700) processor (revision 0x00) with 124928K/6144K bytes of memory.
Processor board ID 15617578
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
3 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
4 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
My Topology:
PBX <---> 3640 <---> VOIP Network
Milton
1 REPLY
Anonymous
N/A
Re: ISDN Issue
For data PRI, you might need a CT1/CE1 PRI NM and for voice PRI, you might need an NM-HDV.
80
