12-20-2006 09:21 AM - edited 03-15-2019 04:45 AM
We have a C2801 gateway with SRST and several IP phones behind. From last week people aren't able to make incoming and outgoing calls from and to PSTN. The ISDN LAyer 2 is down. It doesn't get to be up.
This the output of the debug isdn q921:
Dec 20 17:15:59.520 MET: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
Dec 20 17:15:59.520 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=127
Dec 20 17:16:00.520 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:00.532 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
Dec 20 17:16:01.520 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:01.532 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
Dec 20 17:16:02.520 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:02.532 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
Dec 20 17:16:09.528 MET: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
Dec 20 17:16:09.528 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=127
Dec 20 17:16:10.528 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:10.540 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
Dec 20 17:16:11.528 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:11.540 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
Dec 20 17:16:12.528 MET: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 20 17:16:12.540 MET: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
and so on....
Does anyhone know how to make the ISDN interface to be up??
12-25-2006 10:33 PM
Can you post the whole config of your router ?
If you are trying to dial using PSTN onto a ISDN line i dont think it will work.
regds
12-26-2006 02:44 AM
The problem was solved last friday, changing the BRIs card.
Thanks for all.
