07-27-2001 12:38 AM - edited 03-12-2019 12:03 PM
Can anybody tell me how can I set or remove the ISDN presentation bit on Cisco AS5300. The only info I found is that with newer IOS versions it's possible but I don't know how.
Thanks.
08-07-2001 12:49 PM
Call Manager Gateway Configuration Screen has a drop-down box that allows you to select the presentation bit (enable/disable).
08-08-2001 11:07 PM
Hi Thomas,
Thanks for your reply but what I wanted were to find out if is it possible to manipulate the ISDN presentation indicator on a Cisco Voice Gateway. For example, not to pass to PSTN the origin number of an incoming call. If you or anybody else knows the answer please help.
Regards.
