ISDN PRI Call problem
User is calling from the PBX and gets busy signal. The PBX is connected to the cisco gateway via PRI line. What can be the problem ?
*Mar  1 02:39:39.803: ISDN Se1/0:15 Q931d: L3IF_rx_L2_pak: received data
*Mar  1 02:39:39.807:   080200130504038090A31803A983946C
*Mar  1 02:39:39.807:   05008132303570088133343737383534
*Mar  1 02:39:39.807:   7C038090A37D029181
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: L3_Go: source 0x020A, event 0x0005, call id 0x     int id 0x0
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: L3_Go: event 0x5  cr_len 2 cr 32787
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 0 event 0x5 ces 1
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 SETUP:U0_Setup(nlcb)
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: L3_state_change: callref 0x8013 old NULL_STATE, new CALL_PRESENT
*Mar  1 02:39:39.807: ISDN Se1/0:15 Q931d: extract_called_number: Extracted called number 3477854
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: extract_called_number: Extracted called number 3477854
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: CCIE_BuildChanId_IE: int_ident_len 0
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: L3_Go: source 0x0400, event 0x00A8, call id 0x     int id 0x13
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: L3_Go: event 0xA8  cr_len 2 cr 32787
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 6 event 0xA8 ces 1
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 CC_MORE_INFO_REQ:U6_MoreInfoReq(nlcb)
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: srl_send_l3_pak:
        source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
        priv_len = 4 int_id = 0x64D7DFAC datasize = 26
*Mar  1 02:39:39.811: ISDN Se1/0:15 Q931d: data =
*Mar  1 02:39:39.811:   64D7DFAC000003000240044300010200
*Mar  1 02:39:39.815:   080280130D1803A98394
*Mar  1 02:39:39.815: ISDN Se1/0:15 Q931d: L3_state_change: callref 0x8013 old CALL_PRESENT, new OVERLAP_RECEIVE
*Mar  1 02:39:54.815: ISDN  LIFd: l3_timer: timer Expiry (0x6543DB70), timer_type (0x1312)
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: source 0x0300, event 0x1312, call id 0x     int id 0x8013
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: event 0x1312  cr_len 0 cr 0
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 25 event 0x1312 ces 1
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 T302_EXPIRY:U25_T302Expiry(nlcb)
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: U25_T302Expiry: T302 expired
*Mar  1 02:39:54.815: ISDN  LIFd: isdn_L3_timer_process:  event_count (1)
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: extract_called_number: Extracted called number
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: source 0x0400, event 0x0088, call id 0x     int id 0x13
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: event 0x88  cr_len 2 cr 32787
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 25 event 0x88 ces 1
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 CC_CALL_PROC_REQ:U25_CallProcReq(nlcb)
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: srl_send_l3_pak:
        priv_len = 4 int_id = 0x64D7DFAC datasize = 21
*Mar  1 02:39:54.815: ISDN Se1/0:15 Q931d: data =
*Mar  1 02:39:54.819:   64D7DFAC000003000240044300010200
*Mar  1 02:39:54.819:   0802801302
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_state_change: callref 0x8013 old OVERLAP_RECEIVE, new IN_CALL_PROC
*Mar  1 02:39:54.819: ISDN Se1/0:15 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(0x3A): b channel 19, call id 0x13
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_Go: source 0x0400, event 0x0084, call id 0x     int id 0x13
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_Go: event 0x84  cr_len 2 cr 32787
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 9 event 0x84 ces 1
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 CC_DISCONNECT_REQ:Ux_DiscReq(nlcb)
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: srl_send_l3_pak:
        priv_len = 4 int_id = 0x64D7DFAC datasize = 25
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: data =
*Mar  1 02:39:54.819:   0802801345080282BA
*Mar  1 02:39:54.819: ISDN Se1/0:15 Q931d: L3_state_change: callref 0x8013 old IN_CALL_PROC, new DISCONNECT_REQUEST
*Mar  1 02:39:54.899: ISDN Se1/0:15 Q931d: L3IF_rx_L2_pak: received data
*Mar  1 02:39:54.899:   080200134D08028090
*Mar  1 02:39:54.899: ISDN Se1/0:15 Q931d: L3_Go: source 0x020A, event 0x004D, call id 0x     int id 0x0
*Mar  1 02:39:54.899: ISDN Se1/0:15 Q931d: L3_Go: event 0x4D  cr_len 2 cr 32787
*Mar  1 02:39:54.899: ISDN Se1/0:15 Q931d: L3_Go: call_id 0x13 cr 0x8013 state 11 event 0x4D ces 1
*Mar  1 02:39:54.899: ISDN Se1/0:15 Q931d: L3_ProcessEvent: callref = 0x8013 RELEASE:U11_Release(nlcb)
*Mar  1 02:39:54.903: ISDN Se1/0:15 Q931d: srl_send_l3_pak:
*Mar  1 02:39:54.903: ISDN Se1/0:15 Q931d: data =
*Mar  1 02:39:54.903:   64D7DFAC000003000240044300010800
*Mar  1 02:39:54.903:   080280135A
*Mar  1 02:39:54.903: ISDN Se1/0:15 Q931d: L3_state_change: callref 0x8013 old DISCONNECT_REQUEST, new NULL_STATE
*Mar  1 02:39:54.903: ISDN Se1/0:15 Q931d: CC_CHAN_GetUserpri: using call_id = 0x13
Everyone's tags (3)
Hall of Fame Super Gold
Take "debug isdn q931" only. Do not take any other debugs.
*Mar  1 22:39:36.930: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0021
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Calling Party Number i = 0x0081, '205'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, '2484810'
                Plan:ISDN, Type:Unknown
        Low Layer Compat i = 0x8090A3
        High Layer Compat i = 0x9181
*Mar  1 22:39:36.938: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8021
*Mar  1 22:39:46.522: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0021
        Cause i = 0x8090 - Normal call clearing
*Mar  1 22:39:46.526: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8021
*Mar  1 22:39:46.534: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0021
*Mar  1 22:39:56.146: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0022
                Standard = CCITT
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Called Party Number i = 0x81, '3477854'
*Mar  1 22:39:56.154: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8022
*Mar  1 22:40:01.810: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0022
*Mar  1 22:40:01.814: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8022
*Mar  1 22:40:01.822: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0022
*Mar  1 22:43:31.522: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0026
                Standard = CCITT
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Called Party Number i = 0x81, '02668275077'
*Mar  1 22:43:31.530: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8026
*Mar  1 22:43:38.990: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0026
*Mar  1 22:43:38.994: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8026
*Mar  1 22:43:39.002: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0026
Re: ISDN PRI Call problem
Are you using CUCM? CHeck that it is configured to do something the called numbers, 2484810, 3477854, 02668275077.
there is no CUCM, call is coming from PRI line and goes to the SIP provider. If the user dials and waits 10 second he can talk I think this is a problem related with the PBX.
The logic is the same, there is no voip dial-peer configured to route the call.
You can take the same trace for a succesful call, then look at the difference.
1216
