ISDN PRI DMS100 interface identifier setting - IOS??
Does anyone know if IOS has the option to configure the DMS100 interface Identifer?
In Call Manager MGCP GW config this is configurable, but H323 can't configure it so were forced to use MGCP. Since we can't set this in IOS we can't use SRST on this router with the PRI either.
Any ideas to get router to work w/PRI in SRST mode?
We have to use DMS100 because of customers PBX type (option 61c). On 61c NI switchtype is limited to PSTN connections. Router has to be network-side as well.
Re: ISDN PRI DMS100 interface identifier setting - IOS??
I guess it can be implemented only in MGCP and not in H.323.
I've not had to configure this on 61c/81c integrations before. The config. I and others have used repeatedly is:
On the IOS gateway:
isdn switch-type primary-dms100
controller T1 1/0
framing esf
clock source line primary
linecode b8zs
pri-group timeslots 1-24
interface Serial1/0:23
isdn incoming-voice voice
isdn flip-chan-flag
!If on earlier version of IOS (12.1.x)
!isdn tei-negotiation first-call
Nortel Meridian Option X
1) Meridian 81c using NI2 Network side will only process the last 4-5 digits of any number, so tandeming to the PSTN is not possible (in fact, if the last 4-5 digits of the number sent out match a PBX phone extension that phone will ring).
2) Set Meridian PRI to S100 Network side if software allows. Successful integrations seem to be running version 22 or later on the Meridian.
3) Must set "S100" on the trunk group (RDB) and on the D-channel config. They can then set the PBX for network side.
4) Set gateway for DMS100 User side. Caller name should work with IOS 12.2(5)+
5) Make sure PBX tech downloads MSDL channel if D channel does not come up. IMPORTANT!
6) PBX tech will also have to make sure correct parameters are set to pass calls from his PRI to CallManager to PRI on PSTN (NCOS, TGAR, others)
Here is some pertinent config info from a Meridian PBX that is
working with
the above PRI
On the D-Channel:
CTYP MSDL
GRP 1
DNUM 15
PORT 2
USR PRI
DCHL 25
OTBF 128
PARM RS422 DTE
CLOK EXT
IFC S100
SIDE NET
CNEG 1
RLS ID **
RCAP ND2
On a trunk (ds0)
TYPE TIE
CDEN SD
CUST 0
TRK PRI
PDCA 1
PCML MU
NCOS 2 <<< Depends on permissions in switch
RTMB 79 1
B-CHANNEL SIGNALING
TGAR 1 <<< Routing code. Could be different.
AST NO
IAPG 0
CLS CTD DTN and so on
TKID
FCAR NO
On the trunk route:
TKTP TIE
ESN NO
CNVT NO
SAT NO
RCLS EXT
DTRK YES
DGTP PRI
ISDN YES
MODE PRA
IFC S100
SBN 0
PNI 00000
NCNA YES
NCRD NO <<<< Can be set to yes
CHTY BCH
CTYP UKWN
INAC NO
ISAR NO
DARC NO
BCOT 0
DSEL 3VCE <<< also works as VOD
PTYP PRI
AUTO NO
DNIS NO
ICOG IAO
SRCH RRB <<< Can be set to LIN (linear hunt)
TRMB YES
STEP
ACOD 7979
TCPP NO
TARG 01
CLEN 1
BILN NO
OABS
INST
IDC NO
DCNO 0 *
NDNO 0
DEXT NO
ANTK
SIGO STD
ICIS YES
and so on ......
510
