ISDN Service msg problem
I have CCM connected to a Nortel Option 81c via 3640 router, NM-HDV, T1/PRI card. Protocol on CCM is DMS-100, on 81c is SL-100. Every four minutes the CCM sends a service message, if I do debug isdn q931 this is what I see:
ISDN Se0/0:23: TX -> SERVICE pd = 3 callref = 0x0000
Change Status i = 0xC0 - in-service
Channel ID i = 0xE9808382
I am not sure why this is happening, all the channels are in service at both ends of the PRI.
The problem is, when the PBX sees this come across the PRI, it generates a bug message BUG1369 Loop # out of range BCH_TO_TN.
Has anyone seen this problem? I have opened two TAC cases on this but no success.
Re: ISDN Service msg problem
What version of call manager is this? Is this an MGCP GW? It sounds like you are hitting CSCdv86713, this can be found in the bug toolkit:
http://www.cisco.com/support/bugtools/Hope this helps,
Chester
I'm running 3.1(2c), yes it is an MGCP gateway.
I know about that particular bug. I have gotten a patch (es30a) from TAC to put on my CCM server, which I will be doing this Wednesday.
I thought perhaps someone on this forum had experienced the problem on their CCM and might have insight. I'll post the results of implementing the patch.
I installed es30a this morning, so far no errant service messages for over 6 hours. I'm reluctant to call it "fixed" until at least 24 hours without messages, but it looks promising.
143
