Community Member
ISDN SETUP ISSUES
I have tried about every variation of ISDN config and cannot get the incoming setups to work. As far as I know now it is telling me blah about the bearer cap but I thought that was usually for a voice call coming in on a data line.
Anythoughts would help.
ul 14 15:39:37.932: ISDN Se0:23: RX <- SETUP pd = 8 callref = 0x0279
Jul 14 15:39:37.932: Bearer Capability i = 0x8090A2
Jul 14 15:39:37.932: Channel ID i = 0xA18390
Jul 14 15:39:37.932: Calling Party Number i = 0x21, 0x83, '5555551212', Plan:ISDN, Type:National
Jul 14 15:39:37.932: Called Party Number i = 0xA1, '2345678900', Plan:ISDN, Type:National
Jul 14 15:39:37.936: ISDN Se0:23: Incoming call id = 0x02CF, dsl 0
Jul 14 15:39:37.936: ISDN Se0:23: NegotiateBchan: bchan 16 intid 0 serv_st 0 chan_st 0 callid 0x0000 ev 0x90 n/w? 0
Jul 14 15:39:37.936: Negotiated int_id 0 bchan 0 cr=0x8279 callid=0x02CF lo_chan 16 final int_id/bchan 0/16 cause 0x0
Jul 14 15:39:37.936: ISDN Se0:23: LIF_EVENT: ces/callid 1/0x2CF CALL_INCOMING
Jul 14 15:39:37.936: ISDN Se0:23: CALL_INCOMING dsl 0 bchan 15
Jul 14 15:39:37.936: extract_sa: no 0x71 ie to extract
Jul 14 15:39:37.936: ISDN Se0:23: CALL_INCOMING: call type is VOICE ULAW, bchan = 15
Jul 14 15:39:37.936: ISDN Se0:23: Event: Received a call id 0x2CF with a bad bearercap from 9172178812 on B16
Jul 14 15:39:37.940: ISDN Se0:23: CCPRI_ReleaseCall(): bchan 16, call id 0x2CF, call type VOICE
Jul 14 15:39:37.940: CCPRI_ReleaseChan released b_dsl 0 B_Chan 16
Jul 14 15:39:37.940: ISDN Se0:23: LIF_EVENT: ces/callid 1/0x2CF CALL_CLEARED
Jul 14 15:39:37.940: ISDN Se0:23: received CALL_CLEARED call_id 0x2CF
Jul 14 15:39:37.940: no resend setup, no redial
Jul 14 15:39:37.940: ISDN Se0:23: TX -> RELEASE_COMP pd = 8 callref = 0x8279
Jul 14 15:39:37.940: Cause i = 0x80BA - Bearer capability not available
Community Member
Re: ISDN SETUP ISSUES
Forgot conf
!AS5300 ISDN FAS-----
isdn switch-type primary-5ess
isdn voice-call-failure 0
interface Serial0:23
no ip address
no cdp enable
Jason,
Have you set a voice codec statement and applied it to the incoming dial peer so the AS-5300 knows what codec it should use?
AS5300s are a little more picky than your normal gateway and take a little more setting up. Any chance you could post the whole config (passwords ommitted) so it'll be easier to tell.
Paul
Community Member
Thanks and sure...I used the config I had from another 5300 that was pretty much the same 5ess etc so I just cut n pasted most everything. This one I think the carrier is just sending something extra or missing it (the noteable diff I see was the new carrier sends ANI)...
I pulled all the radius and access stuff because I am positive that is not part of the issue.
resource-pool disable
call rsvp-sync
clock timezone EST -5
ip subnet-zero
signaling-class cas test
voice rtp send-recv
voice class codec 1
codec preference 1 g729r8
codec preference 2 g723r63
codec preference 3 g711ulaw
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 0
framing esf
clock source line primary
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
controller T1 1
framing esf
clock source line secondary 1
linecode b8zs
interface Ethernet0
ip address
no ip route-cache
no ip mroute-cache
no ip address
isdn negotiate-bchan
no cdp enable
interface Serial1:23
no ip address
isdn guard-timer 3000
isdn T203 10000
no cdp enable
interface FastEthernet0
ip address
duplex full
speed auto
interface Dialer0
no ip address
no cdp enable
interface Dialer1
no ip address
no cdp enable
ip classless
no ip http server
ip pim bidir-enable
logging trap debugging
voice-port 0:D
voice-port 1:D
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 212 voip
destination-pattern 212T
session target ipv4:
dial-peer voice 718 pots
destination-pattern 1718.......
port 1:D
alias exec u undebug all
line con 0
line aux 0
end
I can't see anything in your config that matches the incoming dialled digits.
You need a
dial-peer voice xx voip
destination-pattern 234T
session target ipv:
voice codec 1
type of statement. As far as I can tell your incoming calls don't go anywhere becasue you haven't told them where to go nor which codec to use.
paul
Community Member
ok I did the voice codec as below same thing though the digits were just fakes I typed in. Here is a real example
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
no ip address
no cdp enable
dial-peer voice 212609 voip
voice-class codec 2
ul 14 18:40:23.200: ISDN Se0:23: RX <- SETUP pd = 8 callref = 0x0283
Jul 14 18:40:23.200: Bearer Capability i = 0x8090A2
Jul 14 18:40:23.200: Channel ID i = 0xA18383
Jul 14 18:40:23.200: Calling Party Number i = 0x21, 0x83, '5555551212', Plan:ISDN, Type:National
Jul 14 18:40:23.200: Called Party Number i = 0xA1, '2126093474', Plan:ISDN, Type:National
Jul 14 18:40:23.204: ISDN Se0:23: Incoming call id = 0x02D9, dsl 0
Jul 14 18:40:23.204: ISDN Se0:23: NegotiateBchan: bchan 3 intid 0 serv_st 0 chan_st 0 callid 0x0000 ev 0x90 n/w? 0
Jul 14 18:40:23.204: Negotiated int_id 0 bchan 0 cr=0x8283 callid=0x02D9 lo_chan 3 final int_id/bchan 0/3 cause 0x0
Jul 14 18:40:23.204: ISDN Se0:23: LIF_EVENT: ces/callid 1/0x2D9 CALL_INCOMING
Jul 14 18:40:23.204: ISDN Se0:23: CALL_INCOMING dsl 0 bchan 2
Jul 14 18:40:23.204: extract_sa: no 0x71 ie to extract
Jul 14 18:40:23.204: ISDN Se0:23: CALL_INCOMING: call type is VOICE ULAW, bchan = 2
Jul 14 18:40:23.204: ISDN Se0:23: Event: Received a call id 0x2D9 with a bad bearercap from 5555551212 on B3
Jul 14 18:40:23.208: ISDN Se0:23: CCPRI_ReleaseCall(): bchan 3, call id 0x2D9, call type VOICE
Jul 14 18:40:23.208: CCPRI_ReleaseChan released b_dsl 0 B_Chan 3
Jul 14 18:40:23.208: ISDN Se0:23: LIF_EVENT: ces/callid 1/0x2D9 CALL_CLEARED
Jul 14 18:40:23.208: ISDN Se0:23: received CALL_CLEARED call_id 0x2D9
Jul 14 18:40:23.208: no resend setup, no redial
Jul 14 18:40:23.208: ISDN Se0:23: TX -> RELEASE_COMP pd = 8 callref = 0x8283
Jul 14 18:40:23.208: Cause i = 0x80BA - Bearer capability not available
Community Member
voice class codec 2
no ip address
no cdp enable
voice-class codec 2
A couple of remarks. If you decode the bearer capability you get this
Information Transfer Capability:
Speech
Transfer Mode:
Circuit Mode
Information Transfer Rate:
64 Kbps
User Information Layer 1 Protocol:
G.711 u-Law Speech
Also a Paul pointed out your voip peer is not correct:
voice-class codec 2
You need to have an ip address of ccm specified for this command: session target ipv4
like session target ipv4:10.48.80.41
Ullie
Try adding isdn incoming-voice voice to interface Serial 0:23.
Also, look at show version and make sure you have some voice resources listed.
197
