10-09-2013 10:20 PM - edited 03-13-2019 08:22 PM
Hi All,
I was trying to upgrade a voice gateway AS5350XM from 12.4T(20)T4 to 15.1(1)T5 and the voice gateways loaded with the new IOS, however the voice-port configuration gone. I tried to configure the connection plar under voice-port but I got below error
connection plar is not allowed on NP DFC
Any idea???
M.Sherif
10-11-2013 02:14 AM
You can use a translatio rule to translate all called number to the destination that you want.
10-20-2013 02:56 AM
Hi Paolo,
I already tried the translation rule but it didn't work, kindly check below configuration and debug
voice translation-rule 2
rule 1 /.*/ /9344/
voice translation-profile Divert1
translate called 2
voice-port 3/0:0
translation-profile incoming Divert1
HOIPCCVG2#test voice translation-rule 2 5
Matched with rule 1
Original number: 5 Translated number: 9344
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
HOIPCCVG2#
HOIPCCVG2#
HOIPCCVG2#test voice translation-rule 2 0015
Matched with rule 1
Original number: 0015 Translated number: 9344
HOIPCCVG2#test voice translation-rule 2 920003344
Matched with rule 1
Original number: 920003344 Translated number: 9344
HOIPCCVG2#debug voip dialpeer
HOIPCCVG2#sh voic cal sum
PORT CODEC VAD VTSP STATE VPM STATE
3/0:0.1 g711ulaw n S_DIGIT_COLLECT CSM_IC7_CONNECTED
*Oct 20 09:15:56.177: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=506184032, Called Number=9344, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
*Oct 20 09:15:56.177: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Oct 20 09:15:56.357: %SYS-3-INVMEMINT: Invalid memory action (malloc) at interrupt level -Traceback= 0x6394DC40z 0x620F091Cz 0x620ECD08z 0x620ECF30z 0x620ED5DCz 0x620E9E40z 0x626346CCz 0x62635408z 0x626011A0z 0x62603D70z 0x62B84D38z 0x602E42D4z 0x602E0E6Cz 0x602E1E08z 0x6026505Cz 0x60267644z
*Oct 20 09:15:56.357: %SYS-2-MALLOCFAIL: Memory allocation of 512 bytes failed from 0x620FC134, alignment 0
Pool: Processor Free: 240350408 Cause: Interrupt level allocation
Alternate Pool: None Free: 0 Cause: Interrupt level allocation
-Process= "
*Oct 20 09:16:03.621: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=505911063, Called Number=9344, Voice-Interface=0x0,
*Oct 20 09:16:03.621: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Oct 20 09:16:03.825: %SYS-3-INVMEMINT: Invalid memory action (malloc) at interrupt level -Traceback= 0x6394DC40z 0x620F091Cz 0x620ECD08z 0x620ECF30z 0x620ED5DCz 0x620E9E40z 0x626346CCz 0x62635408z 0x626011A0z 0x62603D70z 0x62B84D38z 0x602E42D4z 0x602E0E6Cz 0x602E1E08z 0x6026505Cz 0x60267644z
HOIPCCVG2#
Mohamed Sherif
10-20-2013 11:28 PM
Any idea !!!
M.Sherif
