Community Member
Issue with CME/CUE and inbound VOIP call from another Router
I have a CME/CUE configuration on a 3745. When I call from IP phone to IP phone off the 3745 all calls work and all calls role to VM as they should.
When I place a call from and anlog phone (FXS port) off another ethernet attached router to a CME IP phone via a VOIP dial-peer the call will complete and all is well.
However, If I let this H.323 based call (analog to CME phone) role to VM I just get a fast busy.
I have complete IP connectivity from CME and CUE to the 3640 router hosting the analog phone.
Any Ideas?
the dial peers for the two router are:
3745 CME router
dial-peer voice 110 voip
Description to 3640 anlog phone
destination-pattern 204.
progress_ind setup enable 3
session target ipv4:142.6.66.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
3640 router with Analog phone on FXS
Description to all CME IP phones on 3745
destination-pattern 1...
session target ipv4:192.168.1.1
codec g711ulaw
no vad
1 ACCEPTED SOLUTION
Re: Issue with CME/CUE and inbound VOIP call from another Router
Your inbound call leg is H323 based. When it rolls over to voicemail, CME sends the call to CUE via SIP. To join both these calls together, the router by default does not do it. You have to configure,
voice service voip
allow connection h323 to sip
redirect ip2ip
PS: Let me know if that worked! If yes please remember to rate helpful posts!
voice service voip
redirect ip2ip
Community Member
That appeared to do the trick. Thanks very much for the feedback.
154
