Issue with MGCP 2651xm & AT&T PRI Megacom
Hi ,
I have an issue with a T1 service whereby outbound calls fail with i.e missing.
The GW is a 2651xm running MGCP.
Inbound calls are ok. When making an outbound call on the Megacom At&t PRi 24 channel service.
I see
NY-Vg02-T1#
Mar 9 21:43:17.421: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0007
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x1181, '8208'
Plan:ISDN, Type:International
Called Party Number i = 0x91, '011blahblah'
Mar 9 21:43:17.465: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
8007
Cause i = 0x83E020 - Mandatory information element missing
Not quite sure if the AT&T 4ess switch requires some specific IE when we use this megacom service and if it does where to set it
If I change the information to say ACCUNET switched digital service on the route pattern I get this --> Service/option not available, unspecified
Mar 9 21:51:35.919: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0009
Standard = CCITT
Net Specific Fac i = 0x00E6
Called Party Number i = 0x91, '011blah blah'
Mar 9 21:51:35.983: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
8009
Cause i = 0x83BF - Service/option not available, unspecified
Any 1 have a solution to this issue ...
Thanks regards
Allan
Re: Issue with MGCP 2651xm & AT&T PRI Megacom
If you are using this with CallManager, you will need to setup up the ISDN Network-Specific Facilities Information Element at the bottom of the route pattern you are going out of. It is near the bottom of this link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed685.html#wp1023973
As already mentioned and displayed in my first post I tried all options on the route p[oint without success.
Thanks Anyway
Allan, have you tried setting any CIC's on your NSF settings ?
Adding to Steve's post, in the RP config page, selecting the switch type as 4ESS or 5E9 gives you the option for specifying Megacom telcom service.
402
