Issue with VG200 voice-port 1/1/1 constantly connected
shaftstri
Sh ccm-manager shows registered
In CM the vg200 with NM-2v says registered to CM
The NM-2v has 4fxs ports 2 cards with 2 FXS ports on on each card.
sh voice call summary shows port 1/1/1 is constantly connected.
When this shouldnt be the case.
When number is dialed we receive reorder tone.
rebooted the box to no avail same issue persisits.
ant suggestions
thankyou.
sbilgi
Level 5
Level 5
Try to add the command "progress_ind setup enable " to the voip dial peers and see if it works.
allan.wells
Level 3
Level 3
I've had this issue before after a move, try removing the cable and reseating it then reboot box.
If this fails try swapping card with another thats working if you can and this will let you know if RMA is required.
Allan
