Issues with fax on VG248
Our client is experiencing problem with faxes on VG248 from the day one. The faxes recieved are not always complete, there are comm error report on the fax machines.Has anyone experiened similar problem with faxes on VG248. VG248 is configured for fax relay enabled and call manger version is 3.3.2 Whats the best way of configuring VG248.
Re: Issues with fax on VG248
We aslo have battled the fax machines with the VG248. We have disabled fax relay and played with the output gain and input gain of each individual port that a fax machine is attached to. I have found that using -5 for the input gain and -4 for the output gain seems to work the best. I have also set fax relay ECM to disabled and Fax relay NSF to Override with 000000.
Currently running 7 different fax machines through a 248. Be sure your firmware is of current release - 1.2(1).
Setting's currently being used:
Call Control = Standard
Intput Gain = 0
Output Gain = 0
Digit Detection = Default: Use DSP
Fax Relay = Disabled
Passthrough mode = Default: Automatic
Good Luck!!
If your calls are coming in through T1/PRI gateway, verify there are no slips or errors there. I had same issues and problem was clock source on T1 circuit was not set to "network". Slip was introduced and caused faxes to work intermittantly.
212
