Issues with TCL on CME in order to block calls
I am trying to use TCL in order to block calls on IP phones connected to a Cisco Call Manager Express. I configured a dial-peer voice 18 voip with destination-pattern *19T and application authentication. However as soon as I dial *19xxxxxxxx I get a busy tone. The customer wants to be asked for a pin each time he makes a call. Parts of my configuration is as follows:
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
telephony-service
load 7960-7940 P00303020214
max-ephones 96
max-dn 100
ip source-address 10.70.3.2 port 2000
time-format 24
date-format dd-mm-yy
max-redirect 6
timeouts interdigit 5
system message Data Center El Hatillo
user-locale ES
create cnf-files version-stamp 7960 Aug 09 2006 14:15:27
voicemail 2000
max-conferences 8
moh music-on-hold.au
web admin system name admin password admin
dn-webedit
time-webedit
transfer-system full-consult
login timeout 30 clear 17:00
after-hours block pattern 1 9.......
after-hours block pattern 2 900............
after-hours block pattern 3 900T
after-hours block pattern 4 902.........
after-hours block pattern 5 90412.......
after-hours block pattern 6 90414.......
after-hours block pattern 7 90416.......
after-hours block pattern 8 90417.......
after-hours block pattern 9 90418.......
after-hours block pattern 10 90500.......
after-hours block pattern 11 90501.......
after-hours block pattern 12 90600..........
after-hours block pattern 13 90800.......
after-hours block pattern 14 90900.......
after-hours block pattern 15 91..
after-hours day Sun 00:01 23:59
after-hours day Mon 00:01 23:59
after-hours day Tue 00:01 23:59
after-hours day Wed 00:01 23:59
after-hours day Thu 00:01 23:59
after-hours day Fri 00:01 23:59
after-hours day Sat 00:01 23:59
Bronze
Re: Issues with TCL on CME in order to block calls
Shouldn't voip dial peers have 'session target'?
Not necessarily.
Bronze
i'm not familiar with dial-peer applications but i think you can use 'debug vxml'. hopefully it'll give you more info why it is not working.
You will have to enter the pin command under each ephone and than enable login timeout
For example
ephone 1
pin 1212
after-hour exempt
telephony-service
login timeout
153
