ITEM server problem
Is anyone can suggest how i can solve this error message in the ITEM server?
"An internal error has occurred. Please see srst_ui.log for more detail"
srst_ui.log has this
20-Dec-2005|16:04:41.187|ERROR|SRSTUI_Log|Thread-32|SRSTUICTMClient|refresh|.|Error in CTM Call Invocationcom.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn srsturn : Not found !!
20-Dec-2005|16:04:41.187|ERROR|SRSTUI_Log|Thread-32|SRSTOPerationsAction|perform|.|com.cisco.nm.trx.srst.srstui.application.SRSTException: SRST.lookAtLogError
at com.cisco.nm.trx.srst.srstui.application.SRSTUICTMClient.refresh(SRSTUICTMClient.java:254)
at com.cisco.nm.trx.srst.srstui.action.SRSTOperationsAction.ReadStudies(SRSTOperationsAction.java:160)
at com.cisco.nm.trx.srst.srstui.action.SRSTOperationsAction.perform(SRSTOperationsAction.java:57)
at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:491)
at javax.servlet.http.HttpServlet.service(HttpServlet.java)
at org.apache.tomcat.facade.ServletHandler.doService(ServletHandler.java:574)
at org.apache.tomcat.core.Handler.invoke(Handler.java:322)
at org.apache.tomcat.core.Handler.service(Handler.java:235)
at org.apache.tomcat.facade.ServletHandler.service(ServletHandler.java:485)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:917)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:833)
at org.apache.tomcat.modules.server.Ajp13Interceptor.processConnection(Ajp13Interceptor.java:341)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:494)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:516)
at java.lang.Thread.run(Unknown Source)
thank you
KN
1 REPLY
Silver
Re: ITEM server problem
Check for the device support for ITEM 2.0.
SRST is supported by ITEM 2.0
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/itm/itm_20/devsup/itmdev20.htm
89
