ITS and ATA186
Is it possible with Cisco IOS Telephony Service 2.0 to integrate an ATA186 without an CCM. I need it for fax integration instead of use a vic-2fxs.
Thanks in advance
Martin
Re: ITS and ATA186
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Re: ITS and ATA186
This shouldn't be a problem. Set the outgoing GW as the SIP proxy server in your ATA, and disable SIP registration. Whatever you dial will go to the GW. Enable SIP on the GW and add a default dial peer to route all calls to the PSTN.
Configure G.711 as your codec, don't use fax relay. I am not sure if the fax relays of GWs and the ATA are compatible.
Note also that you need a newer ATA to use higher fax speeds (14.4).
//Thomas.
Re: ITS and ATA186
Hi, Thomas, do you mean that the ATA support Fax Relay? What I always knew is that it does support Fax Bypass (or transparent, or passthrough), which means using G.711 to transmit everything transparently.
Thank you
Paulo.
88
