ITS Design issue
I have a question about ITS 3.0 :
The phone registering to it must BE on the subnet directed connected to the router FE interface or there can be a L3 switch (for example) between the router and the phone? Another (similar) question is if I can use a loopback ip address like registering ip address for the skinny protocol or not.
Thanks in advance,
Fabio
Silver
Re: ITS Design issue
I think the IP phone can get registered with a L3 switch also.
For your second question there is a bug CSCdw12555 with VG200. Check for further detials.
Fabio,
In a lab environment, I have successfully set ip an IP phone on a completely different subnet, separated by a non-ITS router, and it worked. as long as the DHCP scope for the phones hands off the option 150 to the phone, and you have a dial peer set up so that you can call the phone, it should work. I am about to do more of the same in a live environment, so I'll let you know how it goes!
good luck,
Jerry
85
