Community Member
ITS with outgoing call problems
i configured ITS 2.1 and connected via VWIC BRI to a ISDN Port from our PBX.
now i can call from our PBx Phones to the IP Phones. but from the IP Phones to the PBX Phones not. The following debug appear
08:39:08: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 68 changed to up
08:39:08: ISDN BR1/0 Q931: TX -> SETUP pd = 8 callref = 0x2D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Display i = 'Welsch'
Calling Party Number i = 0x0080, '152'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '238'
Plan:ISDN, Type:Unknown
08:39:08: ISDN BR1/0 Q931: RX <- STATUS pd = 8 callref = 0xAD
Cause i = 0x81E328 - Information element not implemented
Call State i = 0x00
08:39:08: ISDN BR1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAD
Channel ID i = 0x89
08:39:08: ISDN BR1/0 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x2Dev 0x2 ces 1 -- Message ignored
08:39:08: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x2D
Cause i = 0x80D1 - Invalid call reference value
08:39:08: ISDN BR1/0 Q931: RX <- ALERTING pd = 8 callref = 0xAD
08:39:08: ISDN BR1/0 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x2Dev 0x1 ces 1 -- Message ignored
08:39:10: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 68 changed to down
What is the problem ?
1 REPLY
Silver
Re: ITS with outgoing call problems
This seems to be a known bug CSCdw50476 on the CCO . The Display information element is not understood by the Call Manager properly. Hence, the ISDN call fails. The earlier Cisco IOS versions on the gateways like AS5300 had this problem .It has been resolved in version 12-2.8.5T, 12-2.6e and later ones.
For confirmation, you can verify all the configurations on the ITS 2.1 from the documents given below.
Cisco IOS Telephony Services Version 2.1
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_book09186a0080153d1f.html
153
