IVR script
Hi All;
As you know, there are bunch of IVR script built to the IOS, where can I find additional IVR script that match business need?
Alex
Re: IVR script
Where are the IVR scripts? I've been looking for them in flash and can't find them.. Is there a .tar for these scripts...
Re: IVR script
do this command (in enable mode):
show call application voice summary
and you should see the list of built-in TCL applications on your voice enabled gateway.
The Cisco TCLware pack can be downloaded from their CCO site (if you possess a CCO account).
122
