Jitter and Humming Noise when placing calls
Hello Guys,
I'm having a problem with Jitter and humming noise when placing calls. This happens anytime we place an outside call-- I will paste the configuration we currently run in our voice-ports for analysis. This problem seems like its getting worse and worse by day. Please let me know if you all have any solution or recommendations.
Current Voice-Port Configuration--
signal groundStart
input gain 6
output attenuation 0
echo-cancel coverage 16
playout-delay maximum 160
playout-delay nominal 80
playout-delay mode fixed
no comfort-noise
connection plar 7050
music-threshold -45
caller-id enable
Re: Jitter and Humming Noise when placing calls
Is there any reason why the gain, attenuation and playout delay buffer are set to non-default values?
Fixed playout delay generally does not work as well as adaptive. Take a look at this page to see how to get jitter stats right off the dsp:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a00800945df.shtml
the music-threshold set as it is may present the echo cancellers with a difficult situation as well.
I have tried different configurations, as I start changing the defaults--the problem seems to get worse and worse. Is there a value you recommend for those configurations? Your input would greatly be appreciated.
Eloy Chio
Bronze
You might consider putting a trouble ticket into your local carrier to have them check the quality of your trunk to the PSTN. Maybe something is not up to speed there, and if not at least you can rule that out.
115
