08-28-2006 11:21 PM - edited 03-13-2019 02:47 PM
on my cisco attendant console , the option for joining and direct transfering calls is greyed out? I have two calls on the same line,
09-04-2006 08:43 AM
make sure your attendant is double-clicking on a call before attempting to transfer it; a single click will not work and some options (like transfer) will be grayed out.
09-04-2006 11:33 AM
What is your CCM version?
How many calls do you have configured in the maximum number of calls in the Line Configuration page?
You probably have this setting set to 2 calls and you need 3, if you are using CCM 3.X then by default there are only 2 calls and can not be changed to 3 or more.
//Jorge
