Lan QoS on 3550
I was reading through the Campus QoS SRND and for the class maps they use match-all instead of match any...given the type of access list i thought it would be match any?
class-map match-all Voice-Control
match access-group name Voice-Control
ip access-list extended Voice
remark Match UDP ports for Bearer Traffic
permit udp any any range 16384 32767
ip access-list extended Voice-Control
remark match voip control traffic
remark sccp
permit tcp any any range 2000 2002
remark h323 fast start
permit tcp any any eq 1720
remark h323 slow start
permit tcp any any range 11000 11999
remark h323 mgcp
permit udp any any eq 2427
Re: Lan QoS on 3550
Dear Friend
If you use match all, all setence have match to trafiic accomplish with class.
If you use match any, enough only one setence match to traffic accomplish with class.
IN this case use match-any, match all is default class method in ios.
Best Regards
Joao Medeiros
Re: Lan QoS on 3550
The match-all or match-any statement refers to the subsequent match lines under the class map;
i.e.
match interface F0/0
Traffic to fall into this class would have to be defined in the ACL and also present on the FastEthernet interface also, whereas
class-map match-any Voice-Control
Traffic would fall into the class if it was defined in the ACL or present on the FastEthernet interface.
HTH.
Bill.
Re: Lan QoS on 3550
I understand the difference between the two. I was questioning why in the SRND the configuration specified match-all instead of match-any. If you used the match-all in the case above you wouldn't get many matches.
Re: Lan QoS on 3550
In the SRND configuration you posted, either the match-all or match-any statements can be used interchangeably because there is only one match statement under each class map.(match access-group voice, and match access-group voice-control. In the voice control case, any line in the ACL that is matched will drop into this class.
Bill.
80
