Community Member
Laptop Console-ing [No 9 Pin Serial]
Hope this is an ideal forum for this post!
I am basically looking at buying a laptop and would need to use it to console to Switches / Routers using the rollover cable etc.
However, I notice most laptops dont come with the 9 pin serial port anymore.
Is there a way of using a laptop still without the serial port, i.e through hyper terminal maybe use a usb - serial converter? If so what is out there? Is anyone in this situation and if so what have they done? to be able to do this?
Steve
1 REPLY
Re: Laptop Console-ing [No 9 Pin Serial]
Yes there are USB-serial convertors.
But some don't support break sequences though.
we used a DSE (Dick Smith Electronics) one that works as a charm;
http://www.dse.co.nz/cgi-bin/dse.storefront/43c18a320cea353a273fc0a87f99071f/Product/View/XH8290
but these are not available all over the world I reckon ;-)
After installing, you can connect to the com port with Hyper terminal
88
