Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
launch status monitor
When I click the launch status monotor, I see "not connected". This never happened before and unity is still functioning , I just couldn't see the ports status.I know if I restart the unity server it'll be OK. But is there any other way can fix this?
Re: launch status monitor
As always, we'll need to know what version of Unity you're running here - if you're at 4.0x did you configure IIS for NTLM vs. HTTPS by any chance? There were a couple of DDTS records I found related to that which sound similiar to the description you give:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdz16906&Submit=Search
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdz16932&Submit=Search
I get the same message. I am using HTTPS with anonymous on 4.0.2 for Domino. Any idea what can cause this?
110
