Community Member
layer 3 EtherChannel explaination
I have these two switches with thier configuratios
Switch1:
interface FastEthernet0/10
switchport trunk encapsulation isl
no ip address
channel-group 1 mode desirable
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface Port-channel1
Switch2:
no ip address
channel-group 1 mode auto
no ip address
no ip address
Pitfall:
((To ensure that all member interfaces maintain the exact same configuration put them in the channel with the channel-group interface command, then apply all subsequent configuration to the port-channel interface.
Note that for layer 3 EtherChannel configurations, member
interfaces must first be designated as routed interfaces before being
put them in the channel-group)).
I am looking for explaination for this phrase in pitfall :(Note that for layer 3 EtherChannel configurations, member
put them in the channel-group)?
1 REPLY
Super Bronze
Re: layer 3 EtherChannel explaination
Basically you have two types of real ports on a switch - routed and switched. Switched ports are for PCs/trunk links and so on, whereas a routed port is like a real router interface with an IP address etc.
You switch a port to a switchport using the 'switchport' command, or to a routed one by entering 'no switchport'.
What the pitfall note is saying is that if you want to have an L3 (or routed) Etherchannel, each port must get the 'no switchport' command before the 'channel-group' commmand.
Your config has ports with 'switchport' enabled, so it is a layer 2 etherchannel.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
114
