LDAP and CCM integration
We have Ext. Mobility running on CCMv4.1(3). When we do external LDAP server integration, the
user ID and password management will be as follow:
If user use Corporate Directory service, IP Phone refers to LDAP Directory Server.
- Administrator manages user name, extension number in LDAP Directory Server.
If user use Extension Mobility feature and User Administration, IP Phone refers to CCM Directory.
- Administrator manages userID, PIN code in the CallManager database.
Please see the attached file for reference. Please advice if this is the case. Thank you.
1 REPLY
Re: LDAP and CCM integration
Here is how i made it for AD integration, u should apply it for your ldap makeing appropriate changes gor your LDAP
Cheers!!
There is AD plug-in in CCM,
-On Domain Controller allow SCHEMA UPDATE, BY CHANGING (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NTDS\Parameters\Schema Update Allowed) and verify that the value is set to 1
-Create OU in your AD
-Then U have to install plug-in, to integrate CCM into AD,
-Change regedit key in HKEY_LOCAL_MACHINE\Software\Cisco Systems, Inc.\Directory Configuration
-In the right pane, double-click the DirAccess registry key (DIRACCESS).
-Delete the false registry entry and enter true as the new registry entry.
-Restart IIS
-With CCMPWDChanger from cmd change passwords for CCM system users
-Browse to C:\dcdsrvr\config, and open the file, UMDirectoryConfiguration.ini, in Notepad.
-In the UMDirectoryConfiguration.ini file, locate the key, UserDirAccess.
-Change the UserDirectAccess value to true.
-In Notepad, choose File > Save to save the file.
-Restart IIS again
-Next within CCM-Users-Access rights-MLA- change value from false to true and insert password for CCMadministrator
So u can add users from CCM to AD
Then, go to CRS Admin page for 1.st time it should give you Directory setup, AD info and just change parts that you configured into CCM and AD and that should be IT
Mail me if it's workin or not!!
Good luck!!!!
115
