LDAPSearch problem
I installed CiscoIPPS_SDK_v4[1].1.1 and used LDAPSearch COM object in my custom code to browse LDAP directory. And it works fine with CallManager 3.2. But I can't get it to work with CallManager 4.1.
Not sure that problem is in COM object since I can browse LDAP on CM 3.2 with LDAPBrowser (www.ldapbrowser.com), but when I try the same on CM 4.1 I can connect and get down to users, but when I want to see user attributes I get [ERROR 32] No such object.
As I said, I can see sn, givenName, telephonNumber, mail… with CM 3.2, but not with CM 4.1.
Any idea?
Are there any settings with LDAP directory I should know about?
Roman
Re: LDAPSearch problem
how do you call the object?
did you try without putting the version in the call;
var s = new ActiveXObject("LDAPSEARCH.LDAPSearchList");
Version?
I have reference to the LDAPSEARCHLib COM object.
And the code is in C#:
LDAPSEARCHLib.LDAPSearchList S = new LDAPSEARCHLib.LDAPSearchListClass();
S.Server = "my server IP";
S.Port = 8404;
S.SearchBase = "ou=users, o=cisco.com";
S.AddReturnAttr("givenName,sn","Name","%1,%2", 20);
S.SearchByPhoneNumber(textBox2.Text);
string xml_output = S.XMLListOutput(1, 1);
XmlDocument xmldoc = new XmlDocument();
xmldoc.LoadXml(xml_output);
XmlNode nameNode = xmldoc.SelectSingleNode(@"//Name");
textBox1.Text = nameNode.InnerText;
on the form in textBox2 I put telephone number and then in the textBox1 I get name and sure name of the person connected to that telephone number.
Code works with CM 3.2, but not with CM 4.1.
I solved problem.
S.AuthName = "cn=Directory Manager, o=cisco.com";
S.AuthPasswd = "cisco";
It works with this.
141
