least call routing
james_wang
We have multiple routes for the same range of called number. I want to use the least cost route as the highest priority and if that one is busy or down, the router can automatically switch to another route.
Do I have to use a Gatekeeper to achieve this or I can use multiple dial-peers with different priority?
bcowley
1st - Assign the gateways to a route group.
2nd - Assign the route groups to a route list in the order you want to try them.
3rd - Assign the route pattern to the route list.
