Legacy Voice/Data Multiplexing
Has anybody had any experience of muxing legacy voice from a PBX and data from an X21 source over a single 2mb leased line. Looking at the spec for the VWIC-2MFT-G703 card it appears to fit the job but I can't find config examples on CCO. I do not want VoIP just old fashioned TDM voice and data.
Re: Legacy Voice/Data Multiplexing
You can generally emulate a T1 between PBXs by using TCCS:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800a96c1.shtml
Use clear channel codec and it should work. You will also be positioned for VoIP with thsi if you ever decide to go that direction.
Not sure it is what I am looking to do, basically just wanted legacy multiplexing for x.21 data and e1 voice over a leased line between 2 sites.
Silver
Use a drop and insert VWIC . There is a little more info here -
http://www.cisco.com/warp/public/788/products/vwicmf_e1.html
Basically you can configure one port to TDM cross connect a group of timeslots to other timeslots on the second port. You have one group reservedfor pure tdm and more timeslots set up as a channel group for the data.
Here is a basic example -
controller e1 0/0
description - connection to PBX
clock source internal
tdm-group 0 timeslots 1-10
controller e1 0/1
description - connection to WAN E1
channel-group 0 timeslots 11-31
tdm-group 1 timeslots 1-10
interface serial 0/1:0
ip address 10.1.1.1 255.255.255.0
cross-connect PBXLink e1 0/0 0 e1 0/1 1
this will connect the first 10 timeslots from e1 0/0 to the first 10 timeslots of e1 0/1 , timeslots 11-31 on e1 0/1 will be used for data between the routers.
The other side would have matching configs
120
