Lightning Fax
Hi,<br><br>I've got Lightning Fax 6.5 running on Unity 2.4.6 box. One of the LF services (LFExGateway) won't start due to a Dr. Watson error. I'm thinking of removing the LFExGateway from Add/Remove Programs but don't know exactly what directory from the install CD (version 2.4.6) to reinstall it back in. Can someone help me with this. Thanks, Dave<br><br>
1 REPLY
Re: Lightning Fax
Look at the install guide for 2.4.6 for installation tips for the ActiveFax software with Unity.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/2_46/inst/inst246.pdf
Best is to rerun the Unity install after you have uninstalled the ActiveFax stuff. That will ensure that you have all the required settings etc.
Anil Verma
Cisco Systems
anilve@cisco.com
121
