Limit of Route Patterns on CallManager ?
Hi Pros,
Wanted to check, I have around 60 RPs on CallManager. My CCM hardware is MCS7825. (1 Pub, 1 Sub)
Would it cause too much load on it if I add say 10 - 20 more RPs on it ?
I am also creating around 12 - 16 new Partitions & CSS each on it.
Pratik
Re: Limit of Route Patterns on CallManager ?
It depends on what else do you have on your system.
Maximum Number of Devices per Server Platform:
- MCS-7845 --> 7500
- MCS-7835 --> 2500
- MCS-7825 --> 1000
- MCS-7815 --> 300
Device wights determine the maximum number of physical devices that can be registered to a
CallManager subscriber. Some IP Pone models support multiple lines (directory numbers or
line appearances). Many IPT deployments have directory numbers that are shared across
multiple IP Phones and a large number of dial plan entries that include route patterns;
translation patterns require an extra amout of resources (CPU,memory) on the CallManager.
Dial plan weights provide the limit on the number os fuch dial plan entries configures in
a CallManager subscriber. Dial plan weight calculations provice guidelines to size the
cluster .
Base Dial Plan Weights:
* IP phone device (excluding lne appearances) -- > 5
* Unique line appearance --> 5
* Shared line appearance --> 4
* Route Pattern --> 2
* Translation Pattern --> 1
What about Partitions & CSS, do they have any weights?
173
