load balance dial peers
Is it possible to load balance accross multiple dial peers (voip and pots)?
If so could someone please give an example or url.
thanks.
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: load balance dial peers
You can try to configure 'dial-peer hunt ' wtih a value of 4 or 5 , so that least recent used dialpeer can be used next , given all other things being equal.
Reference URL below:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122sup/122csum/csum3/122cvvf/vsf_d.htm#xtocid12
For example, if you have 2 destinations for equal numbers to go to, from Router A....
Router A ---- Router B (destination 1 )
|___Router C (destination 2)
then you can create 2 voip peers on Router A, define 'dial-peer hunt 4' on global config, and the router will always use 'least recent use' to choose next dialpeer, and in effect, load balance across.
Hope this helps.
246
