Community Member
Locations and Call Admission Control
CCM 3.3.3 (SR-1)
I have centralized Call Processing with remote locations. I have remote regions to use g.729. The remote location has been setup to allow for 1 g.78 call. We have the location setup to for 24KBS. When I place a call from HQ to the remote region I get a fast busy (Not Enough Bandwidth). If a change the region to g.711 and the location to 80KBS, everything works fine. When I set the region back to g.729 and the location to 24KBS, I get (not enought bandwidth)
Also.... If I up the location to 80KBS and leave the codec on the region to g.729 and make a call and press the Information button, it indicates that the call is indeed g.729, however this only works when I have the location set to 80KBS.
HELP
AND Yes I have reset everthing assoicated to it multiple times.
1 REPLY
Community Member
Re: Locations and Call Admission Control
What happens if you try 32KBS on the g.729 call
106
