Lock / unlock code for ip phones
I need to change the default code for the lock / unlock feature so endusers cannot play with phones. Can I do that? and while I am asking, can the default reset code used on the ip phone be changed to something else?
Re: Lock / unlock code for ip phones
Melvin,
I'm pretty sure you can't change the lock / unlock code from **# but if you are using CM 3.3 you can lock the settings menu away from the users.
That way they can't change anything.
Paul
Paul,
Thanks for the reply, I have done that. The only problem is the screen contrast and ringer is on that menu also. I was thinking about changing the menu so that it does not show the last three choices if I cannot change the codes.
Mel
Mel,
some would say that stopping users constantly changing the ring tone would be a good thing. :-)
Paul
Is there a list of these codes? or are there only the 2 sets (lock/unlock and reset)
thanks
It's just the two that I know of.
Silver
At the phone configuration menu (Call manager 3.3) there is a parameter named "Setting access", the default value is "Enabled", if you change it to "Disabled" you can lock the setting key at the phone.
where could i find this parameter in ccm??
You will find it under "device", then "phone", then select a phone and on the phone configuration page at the bottom is where you will find the "settings access" option where you can enable or disable access to the "settings" key.
Hope this helps you, locking people from this also locks them out of adjusting their own ring volume.
176
