Lock/Unlock Phone using IDLE facility and programming...
joemgalway
Hi ,
anyone lead me down the correct path? Have access to Java developer to do the java bit...
Want to use IDLE function of Cisco phones to show users a screen with just a PIN , everything is disabled , until they enter the PIN....
I know the Extension Mobility will do this ( as in it will log off/on users) but want this to happen automatically after X minutes of inactivity...
Maybe a 3rd party app to lock down Cisco 7940 phones?
Thx
Joe
aaronw.ca
Level 5
Level 5
What if you set the idle URL to the extension mobility logout URL? Wouldn't that accomplish the same goals?
