long distance call and mobile
i have an issue with to forward call to Long distance and mobile.
CCME:3.4
Issue:
test1:
have ip phone 2566 forward all on mobile phone
when another ip phone dials 2566 the call is forward to mobile phone ok
When you call 2566 via PSTN, call is not answered. we have this message on isdn trace
CCME_2811_34_Server#
Jul 10 14:20:14.648: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x3B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2083, '614285194'
Plan:Unknown, Type:National
Called Party Number i = 0x81, '2566'
Plan:ISDN, Type:Unknown
Jul 10 14:20:14.668: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xBB
Channel ID i = 0x89
Exclusive, B1
Jul 10 14:20:14.680: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x0, Calling num 00614285194
Jul 10 14:20:14.696: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x1, Called num 00687142036
Jul 10 14:20:14.696: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x28
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2083, '00614285194'
Called Party Number i = 0x81, '00687142036'
Sending Complete
Jul 10 14:20:15.088: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xA8
Channel ID i = 0x8A
Exclusive, B2
Jul 10 14:20:18.640: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x3B
Cause i = 0x87EF - Protocol error; unspecified
Jul 10 14:20:18.652: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x28
Cause i = 0x80EF - Protocol error; unspecified
Jul 10 14:20:18.932: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0xA8
Jul 10 14:20:18.936: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x28
Jul 10 14:20:21.032: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 105 changed to down
Jul 10 14:20:21.032: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jul 10 14:20:30.220: ISDN BR0/0/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Jul 10 14:20:30.224: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jul 10 14:20:30.272: %LINK-3-UPDOWN: Interface BRI0/0/0, changed state to down
1 REPLY
Silver
Re: long distance call and mobile
Try giving this command
no voice local-bypass
By default calls that loopback from one port to the other do not use DSP. By using this command, you are forcing the router to use DSP. That might make a difference.
Anup
728
