LOST PRIVATE PASSWORD PHRASE HELP!
I need to recover a lost private password phrase on ccm 4.1(3) in order to install IPCC. I have found that the tool to do this is 'adminutility.exe'. However documentation states that when adding new subscribers after using the adminutility you must reset the passwords back to the original, which ofcourse I don't have or I would not be using it in the first place. Does anyone know if this is true, or whether there are other means of finding the original private password phrase?
1 REPLY
Re: LOST PRIVATE PASSWORD PHRASE HELP!
I entered the current password (which has been chnaged many times) of the windows administrator account to reset the password in AdminUtility
Put in a check in the VERY top left box
Choose "Set New Password" from the "Options" drop down menu
Type in new password
Re-type in new password
Click OK
Choose ALL server then hit OK
This will take down all the servers in your cluster.
102
