low cost FXS switches
My customers, in SouthEast Asia, would like to know if there is any Cisco VoIP product which has the same features as the 24 FXS blade in Cat6500 where they can connect the analog phones (many of them) and register to CallManager. The idea is that they don't want to throw away the analog phones yet and cannot affort high cost switches such as 4000's or 6500's. Thanks for any reply.
Duc Vu
Re: low cost FXS switches
Do they need high density FXS? If so then it sounds like the VG248 may be a good solution. The data sheet is at:
http://www.cisco.com/warp/public/cc/pd/ga/prodlit/vg2ap_ds.htm
and I believe it should be orderable sometime this month or possibly next. Requires CallManager 3.1 to operate.
Thank you very much. One last question: will it work with Unity as Voice Mail system ?
Duc Vu
If you are asking whether or not you can use Unity as a voicemail system for analog phones that are attached to the VG248, then the answer is yes.
Each of the 48 ports registers to CallManager as a Skinny phone. Therefore the line configuration is the same in CallManager as if it actually were an IP phone, so you can forward to voicemail as usual.
Also, you can configure the VG248 to provide a stuttered dialtone to analog phones if they have a message waiting. And if you have a caller ID unit or phone that has a message waiting indicator light on it, we can cause it to flash if there is a message. I believe they can both be configured for each port.
97
