Lucent PBX and X4604 GWY
I have a T1-Pri connection between Lucent Definity PBX and the Catalyst 4006 gateway for phone integration purpose. Question is: in Lucent config, there is a connect feature which allows three choices; host, network and pbx. Which one should it be for connection between these two units ? Thanks for help.
Duc Vu
Re: Lucent PBX and X4604 GWY
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
There are various ways of doing it the prefered way is to use PBX and USer on the defininty and then set the Catalyst as though it is connecting to the network.
Jason
Try this configuration:
Lucent: PBX
Cisco GW: Protocol side: User
If that doesn't work,
try:
Lucent: PBX
Cisco GW: Protocol Side: Network
Good luck!
90
