What are maestro tools? I had the memory leak problem (event 2019) and would like to know if a permanent fix is available for this problem. I'm running Unity 3.0.2.<br><br>
I am not sure what specific memory leak even 2019 you are referring to, but I can tell you that there are some fixes for memory leaks in 3.1(2) which is posted on CCO. I recommend upgrading to 3.1(2). http://www.cisco.com/cgi-bin/tablebuild.pl/unity-31 You would need to download the full CD images to go from 3.0(2) to 3.1(). Check out the release notes, they have some good info on upgrading.
