Mannual registration for Cisco 7960 IP phone with Call Manager
If I were need to perform a manual registration between an IP phone (Cisco 7960) and Call Manager, and I will like to basically install this IP phone with the IP address whose subnet (vlan) is different from the subnet (vlan) that the Cisco Call Manager is in, how do I do this ?
Additionally, I was not able to mannualy change the IP address setting in the IP phone. The error message is something like "Router is not in the same subnet). When I tried to change the default gatewate setting, I also encountered the same error. Any idea ? Other than mannually configuring the IP addressing and creating a new device entry in the Cisco Call Manager, what else do I have to do ?
1 REPLY
Re: Mannual registration for Cisco 7960 IP phone with Call Manag
Its is just basic routing. As long as the phone can be routed through the network to the Call Manager, the phone will register.
To manually change the IP address in the phone, first be sure to turn off DHCP on the phone. After that, change the IP address and then the default-gateway.
If it still won't work try and ping from the Call Mangager to see if you have a route to the phone.
697
