mark outside redirected calls
Hi all,
PSTN-PBX-bri-Cisco-WAN-Cisco-bri-PBX-ph2(882)
outph3 ph1(881)
#. The phone1 is redirected all ouside calls to phone2.
when I type show isdn active:
Calling Called
Number Number
---N/A--- 882
#. When a call is made directly from 881 to 882:
Calling Called
Number Number
881 882
Q: How can I view the call number(881), when it redirects ouside calls,
or are there any possibilites to mark calls made directly from 881 or redirected by 881.
Thanks a lot.
1 REPLY
Bronze
Re: mark outside redirected calls
Redirecting a Ringing Call to Your Phone
Call PickUp allows you to redirect a call that is ringing on a co-worker's phone to your own phone so that you can answer it.
Call PickUp is a special feature that your system administrator might configure for you, depending on your call-handling needs and work environment. For example, you might use this feature if you typically share call-handling responsibilities with co-workers.
Try:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_user_guide_chapter09186a008040160f.html
114
