Maximum distance between E1 module on router and PBX
Hi all,
as existing equipments locations are sometimes not easy....
I have one of my router (7204VXR/225) with my module (PA-VXB-2TE1+) in a room and my PBX in another room (in order to do PBX interco on E1)
I am searching the maximum distance limit between my 2 equipments that the E1 module can support (i have 40, 45 meters) and if the connection through 3 patch pannels in the middle will make problems.
I did find the module datasheet but no information concerning the distance
If somone knows, thanks to point me to the info.
Best regards
1 REPLY
Re: Maximum distance between E1 module on router and PBX
40-50 meters should not be a problem. You can adjust the signal stregth with the cablelength command under the E1 controller to adjust for distance if you need to.
199
