Blue
Maximum Length of destination pattern
Should this destination pattern work?
8............... (15 dots)
PBX-----(AS5300 E&M)-----CallManager-----6608(PRI)
Legacy phones hanging off of the PBX need to dial a long distance number 312 555 1212 then they need to dial a 5 digit access code at the end (so the entire number they dial is 81312555121212345 - Then it is sent to CallManager where I strip the trailing 5 digits and send it out. This is a requirement of the customer that the 5 digit pin is dialed at the end. Any ideas on how to accomplish this.
1 REPLY
Anonymous
N/A
Re: Maximum Length of destination pattern
Hi, The gateways can accept upto 31 digits as long the interdigit timer doesnt expire. Check out http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fvvfax_c/vvfpeers.htm#xtocid5.
In your case, I only suspect the PBX. May be it is not configured to accept the access code.
125
