maximum tftp servers
what's the maxium tftp server allowed in the cluster? thanks
Green
Re: maximum tftp servers
Ok this answer requieres a deep design overview:
Actually, there is no restriction on the number of servers that can have TFTP service enabled, in Cisco Unified CallManager 4.2 cluster may contain as many as 20 servers, of which a maximum of eight may run the Cisco CallManager service that provides call processing. The other servers may be configured as a dedicated database publisher, dedicated Trivial File Transfer Protocol (TFTP) server, or music on hold (MoH) servers. Media streaming applications (conference bridge or media termination point) may also be installed on a separate server that registers with the cluster.
So your answer is 20...but...
With Cisco Unified CallManager 4.2, you can choose from the following redundancy configurations:
?Two to one (2:1) ? For every two primary subscribers, there is one shared backup subscriber.
?One to one (1:1) ? For every primary subscriber, there is a backup subscriber.
Depending on the redundancy scheme chosen, the call processing subscriber will be either a primary (active) subscriber or a backup (standby) subscriber. In the load-balancing option, the subscriber can be both a primary and backup subscriber. When planning the design of a cluster, you should generally dedicate the call processing subscribers to this function. In larger-scale or higher-performance clusters, the call processing service SHOULD NOT BE enabled on the publisher and TFTP server. Call processing subscribers normally operate in either dedicated pairs or shared pairs, depending on the redundancy scheme adopted. One-to-one redundancy uses dedicated pairs, while two-to-one redundancy uses two pairs of servers that share one server from each pair (the backup server).
Cisco recommends that you enable the Cisco Trivial Transfer Protocol (TFTP) service on two Cisco Unified CallManager servers. Cisco also recommends that you do not enable more than one server with the Cisco TFTP service at a location remote to publisher, over a low-speed WAN link. More than two TFTP servers can be deployed in a cluster, however this configuration can result in an extended period for rebuilding all the TFTP files on all TFTP servers.
You can run the TFTP service on either a publisher or a subscriber server, depending on the site and the available capacity of the server.
When a change occurs in the database for a device, the Database Layer Monitor notifies all the nodes in the cluster that this change has occurred. The TFTP service running on the TFTP servers will see that this change notification occurred, will check the database, read that record, and create the new .cnf.xml file, based on the data in the database.
Hence, no additional configuration is required to 'sync' the TFTP servers, however, any manual updates, new firmware loads for example, will need to be done on each TFTP servers.
For dedicated TFTP servers, you need the TFTP service and Database Layer Monitor activated. Note, no CCM process is required but you still need to purchase a copy of CCM for (SQL) licensing reasons.
By default, the TFTP service supports 60 simultaneous threads. The suggested value for a dedicated TFTP server is 150 for a single processor system and 300 for a dual processor system. A maximum of 500 is allowed to be configured from the application.
Devices that are requesting a configuration file while the TFTP server is processing the maximum number of requests will receive an error message from the TFTP server, which causes the device to wait a length of time and request the configuration file later.
Basically, performance is the most important part when enabling Cisco TFTP service, that why we recommend no more that two Cisco TFTP servers in the cluster...
Details here:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806e8c0a.html#wp1070935
This is great answer.
One more question here: If I have two tftp servers configured under dhcp, are they used as load sharing or backup when phone boots to request image and configuration?
Green
The phone would use the second address configure in Option 150 if it fails to contact the primary TFTP server, thus providing redundancy.
Thanks again. And idea how many retries or how long before the phone contact the 2nd?
165
