MC3810 Fax Problems
Have a MC3810 network, When sending a fax, cannot complete, says "poor line conditions" and only the first part of the first page appears on it, the rest is blank....this happends when using a DID (DISA) to call outside to PSTN,
When calling to a local extension with the same DID)DISA)there is No Problem...this the debug from both sides (source Cisco and destination Cisco) of the failed fax.
Failed Fax From Source
2w3d: ccCallSetupAck (callID=0x247)
2w3d: ccGenerateTone (callID=0x247 tone=8)
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=1, flags=0x1, timestamp=0x47E53E4F, expiration=0x0)
2w3d: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(583), disp(0)
2w3d: cid(583)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
2w3d: ssaIgnore cid(583), st(SSA_CS_MAPPING),oldst(0), ev(10)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=1, duration=4155,tag 0, callparty 0 )
2w3d: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(583), disp(0)
2w3d: cid(583)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
2w3d: ssaDigit
2w3d: ssaDigit, callinfo , digit 1, tag 0,callparty 0
2w3d: ssaDigit, calling 201,result 1
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=0, flags=0x1, timestamp=0x47E63DF7, expiration=0x0)
2w3d: cid(583)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN) oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=0, duration=55,tag 0, callparty 0 )
2w3d: cid(583)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT) oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
2w3d: ssaDigit
2w3d: ssaDigit, callinfo , digit 10, tag 0,callparty 0
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=0, flags=0x1, timestamp=0x47E63E37, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=0, duration=51,tag 0, callparty 0 )
2w3d: ssaDigit
2w3d: ssaDigit, callinfo , digit 100, tag 0,callparty 0
2w3d: ssaDigit, calling 201,result 0
2w3d: ssaSetupPeer cid(583) peer list: tag(10) called number (100)
2w3d: ssaSetupPeer cid(583), destPat(100), matched(1), prefix(), peer(17CB1EC), peer->encapType (5)
2w3d: ccCallProceeding (callID=0x247, prog_ind=0x0)
2w3d: ccCallSetupRequest (Inbound call = 0x247, outbound peer =10, dest=, params=0x17C79E8 mode=0, *callID=0x1616808)
2w3d: ccCallSetupRequest numbering_type 0x81
2w3d: callingNumber=201, calledNumber=100, redirectNumber=
2w3d: accountNumber=, pinNumber=
2w3d: finalDestFlag=0, guid=e328.d442.aa47.04c7.0000.0000.5c7e.df9f
2w3d: peer_tag=2
2w3d: dest_pat 1..
2w3d: digit_strip_checking: dest_pat1..
2w3d: strip 1, peer_string 1..
2w3d: peer_tag=10
2w3d: ccIFCallSetupRequest: (vdbPtr=0x1740094, dest=, callParams={called=100,called_oct3=0x81,calling=201,calling_oct3=0x0,fdest=0, voice_peer_tag=10},mode=0x0)
vdbPtr type = 10
2w3d: ccIFCallSetupRequest: (vdbPtr=0x1740094, dest=, callParams={called=100, called_oct3 0x81,
calling=201,calling_oct3 0x0,fdest=0, voice_peer_tag=10}, mode=0x0)
2w3d: ccSaveDialpeerTag (callID=0x247, dialpeer_tag=
2w3d: ccCallSetContext (callID=0x248, context=0x17C7D00)
2w3d: cc_api_call_proceeding(vdbPtr=0x1740094, callID=0x248, prog_ind=0x8)
2w3d: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(584), disp(0)
2w3d: cid(584)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING) oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
2w3d: -cid2(583)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
2w3d: ssaIgnore cid(584), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
2w3d: cc_api_call_alert(vdbPtr=0x1740094, callID=0x248, prog_ind=0x8, sig_ind=0x1)
2w3d: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(584), disp(0)
2w3d: cid(584)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT) oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
2w3d: ccCallAlert (callID=0x247, prog_ind=0x8, sig_ind=0x1)
2w3d: ccConferenceCreate (confID=0x1616A60, callID1=0x247, callID2=0x248, tag=0x0)
2w3d: cc_api_bridge_done (confID=0xE5, srcIF=0x1740094, srcCallID=0x248, dstCall ID=0x247, disposition=0, tag=0x0)
2w3d: cc_api_bridge_done (confID=0xE5, srcIF=0x1576028, srcCallID=0x247, dstCall
ID=0x248, disposition=0, tag=0x0)
2w3d: cc_api_caps_ind (dstVdbPtr=0x1740094, dstCallId=0x248, srcCallId=0x247,caps={codec=0xEBFF, fax_rate=0x7F, vad=0x3, modem=0x163AEC0 codec_bytes=80, signal_type=2})
2w3d: cc_api_caps_ind (Playout: mode 0, initial 44736,min 0, max 0)
2w3d: cc_api_caps_ind (dstVdbPtr=0x1576028, dstCallId=0x247, srcCallId=0x248, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
2w3d: cc_api_caps_ind (Playout: mode 0, initial 0,min 0, max 0)
2w3d: cc_api_caps_ack (dstVdbPtr=0x1576028, dstCallId=0x247, srcCallId=0x248, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
2w3d: cc_api_caps_ack (dstVdbPtr=0x1740094, dstCallId=0x248, srcCallId=0x247, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
2w3d: cc_api_voice_mode_event , callID=0x247
2w3d: Call Pointer =17C79D4
2w3d: sess_appl: ev(28=CC_EV_CONF_CREATE_DONE), cid(583), disp(0)
2w3d: cid(583)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE) oldst(SSA_CS_MAPPING)cfid(229)csize(0)in(1)fDest(0)
2w3d: -cid2(584)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
2w3d: sess_appl: ev(37=CC_EV_VOICE_MODE_DONE), cid(583), disp(0)
2w3d: sess_appl: Invalid event ID ev(37), cid(583), disp(0)
2w3d: cc_api_call_connected(vdbPtr=0x1740094, callID=0x248)
2w3d: sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(584), disp(0)
2w3d: cid(584)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED) oldst(SSA_CS_CALL_SETTING)cfid(229)csize(0)in(0)fDest(0)
2w3d: -cid2(583)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_ALERT)
2w3d: ccCallConnect (callID=0x247)
2w3d: ssaFlushPeerTagQueue cid(583) peer list: (empty)
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=9, flags=0x1, timestamp=0x47E53E4F, expiration=0x0)
2w3d: cid(583)st(SSA_CS_ACTIVE)ev(SSA_EV_DIGIT_BEGIN) oldst(SSA_CS_CONFERENCING_ALERT)cfid(229)csize(0)in(1)fDest(0)
2w3d: -cid2(584)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCED_ALERT)
2w3d: ccCallDigitBegin (callID=0x248, db=0x1616A84)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=9, duration=4155,tag 0, callparty 0 )
2w3d: cid(583)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DIGIT) oldst(SSA_CS_ACTIVE)cfid(229)csize(0)in(1)fDest(0)
2w3d: ccCallDigitEnd (callID=0x248, de=0x1616A84)
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=3, flags=0x1, timestamp=0x47E63DF7, expiration=0x0)
2w3d: cid(583)st(SSA_CS_ACTIVE)ev(SSA_EV_DIGIT_BEGIN) oldst(SSA_CS_ACTIVE)cfid(229)csize(0)in(1)fDest(0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=3, duration=65,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=6, flags=0x1, timestamp=0x47E63E1F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=6, duration=62,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=4, flags=0x1, timestamp=0x47E63E0F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=4, duration=63,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=8, flags=0x1, timestamp=0x47E63E0F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=8, duration=63,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=3, flags=0x1, timestamp=0x47E63E0F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=3, duration=63,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=6, flags=0x1, timestamp=0x47E63E0F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=6, duration=63,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=5, flags=0x1, timestamp=0x47E63E0F, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=5, duration=63,tag 0, callparty 0 )
2w3d: cc_api_call_digit_begin (vdbPtr=0x1576028, callID=0x247, digit=1, flags=0x1, timestamp=0x47E63DF7, expiration=0x0)
2w3d: cc_api_call_digit (vdbPtr=0x1576028, callID=0x247, digit=1, duration=65,tag 0, callparty 0 )
2w3d: cc_api_call_disconnected(vdbPtr=0x1740094, callID=0x248, cause=0x10)
2w3d: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(584), disp(0)
2w3d: cid(584)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED) oldst(SSA_CS_CONFERENCED_ALERT)cfid(229)csize(0)in(0)fDest(0)
2w3d: -cid2(583)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_ACTIVE)
2w3d: ssa: Disconnected cid(584) state(5) cause(0x10)
2w3d: ccConferenceDestroy (confID=0xE5, tag=0x0)
2w3d: cc_api_bridge_drop_done (confID=0xE5, srcIF=0x1740094, srcCallID=0x248, ds
tCallID=0x247, disposition=0 tag=0x0)
2w3d: cc_api_bridge_drop_done (confID=0xE5, srcIF=0x1576028, srcCallID=0x247, ds
tCallID=0x248, disposition=0 tag=0x0)
2w3d: sess_appl: ev(29=CC_EV_CONF_DESTROY_DONE), cid(583), disp(0)
2w3d: cid(583)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
2w3d: -cid2(584)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_ACTIVE)
2w3d: ccCallDisconnect (callID=0x247, cause=0x10 tag=0x0)
2w3d: ccCallDisconnect (callID=0x248, cause=0x10 tag=0x0)
2w3d: cc_api_call_disconnect_done(vdbPtr=0x1740094, callID=0x248, disp=0, tag=0x0)
Failed Fax From Destination
Interfruver-Corpo#
1w5d: cc_api_call_setup_ind (vdbPtr=0x1779554, callInfo={called=100,called_oct3=
0x0,calling=201,calling_oct3=0x0,called_oct3a=0x0, fdest=1 peer_tag=0},callID=0x172D4C0)
1w5d: cc_api_call_setup_ind type 0 , prot 10
1w5d: cc_process_call_setup_ind (event=0x1616B70) handed call to app "SESSION"
1w5d: sess_appl: ev(23=CC_EV_CALL_SETUP_IND), cid(8051), disp(0)
1w5d: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(8051), disp(0)
1w5d: ccCallSetContext (callID=0x1F73, context=0x15E86D8)
1w5d: ssaCallSetupInd finalDest cllng(201), clled(100)
1w5d: ssaSetupPeer cid(8051) peer list: tag(3) called number (100) tag(4) call
ed number (100) tag(2) called number (100) tag(1) called number (100)
1w5d: ssaSetupPeer cid(8051), destPat(100), matched(3), prefix(), peer(1733C68), peer->encapType (1)
1w5d: ccCallProceeding (callID=0x1F73, prog_ind=0x0)
1w5d: ccCallSetupRequest (Inbound call = 0x1F73, outbound peer =3, dest=, params=0x15E86EC mode=0, *callID=0x161E108)
1w5d: ccCallSetupRequest numbering_type 0x0
1w5d: callingNumber=201, calledNumber=100, redirectNumber=
1w5d: accountNumber=, pinNumber=
1w5d: finalDestFlag=1, guid=e328.d442.aa47.04c7.0000.0000.5c7e.df9f
1w5d: peer_tag=0
1w5d: dest_pat 100
1w5d: digit_strip_checking: dest_pat100
1w5d: strip 0, peer_string 100
1w5d: peer_tag=3
1w5d: ccIFCallSetupRequest: (vdbPtr=0x157B7AC, dest=, callParams={called=100,cal
led_oct3=0x0,calling=201,calling_oct3=0x0,fdest=1, voice_peer_tag=3},mode=0x0) vdbPtr type = 6
1w5d: ccIFCallSetupRequest: (vdbPtr=0x157B7AC, dest=, callParams={called=100, called_oct3 0x0, calling=201,calling_oct3 0x0,fdest=1, voice_peer_tag=3}, mode=0x0)
1w5d: ccSaveDialpeerTag (callID=0x1F73, dialpeer_tag=
1w5d: ccCallSetContext (callID=0x1F74, context=0x181B2F4)
1w5d: cc_api_call_proceeding(vdbPtr=0x157B7AC, callID=0x1F74, prog_ind=0x0)
1w5d: cc_api_call_alert(vdbPtr=0x157B7AC, callID=0x1F74, prog_ind=0x8, sig_ind=0x1)
1w5d: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(8052), disp(0)
1w5d: cid(8052)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING) oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
1w5d: -cid2(8051)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
1w5d: ssaIgnore cid(8052), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
1w5d: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(8052), disp(0)
1w5d: cid(8052)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT) oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
1w5d: ccCallAlert (callID=0x1F73, prog_ind=0x8, sig_ind=0x1)
1w5d: ccConferenceCreate (confID=0x161E180, callID1=0x1F73, callID2=0x1F74, tag=0x0)
1w5d: cc_api_bridge_done (confID=0xB7F, srcIF=0x1779554, srcCallID=0x1F73, dstCallID=0x1F74, disposition=0, tag=0x0)
1w5d: cc_api_bridge_done (confID=0xB7F, srcIF=0x157B7AC, srcCallID=0x1F74, dstCallID=0x1F73, disposition=0, ag=0x0)
1w5d: cc_api_caps_ind (dstVdbPtr=0x1779554, dstCallId=0x1F73, srcCallId=0x1F74, caps={codec=0xEBFF, fax_rate=0x7F, vad=0x3, modem=0x0 codec_bytes=80, signal_type=2})
1w5d: cc_api_caps_ind (Playout: mode 0, initial 9840,min 0, max 0)
1w5d: cc_api_caps_ind (dstVdbPtr=0x157B7AC, dstCallId=0x1F74, srcCallId=0x1F73, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
1w5d: cc_api_caps_ind (Playout: mode 0, initial 0,min 0, max 0)
1w5d: cc_api_caps_ack (dstVdbPtr=0x157B7AC, dstCallId=0x1F74, srcCallId=0x1F73, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
1w5d: cc_api_caps_ack (dstVdbPtr=0x1779554, dstCallId=0x1F73, srcCallId=0x1F74, caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1 codec_bytes=30, signal_type=2})
1w5d: cc_api_voice_mode_event , callID=0x1F74
1w5d: Call Pointer =181B2F4
1w5d: sess_appl: ev(28=CC_EV_CONF_CREATE_DONE), cid(8051), disp(0)
1w5d: cid(8051)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_MAPPING)cfid(2943)csize(0)in(1)fDest(1)
1w5d: -cid2(8052)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
1w5d: sess_appl: ev(37=CC_EV_VOICE_MODE_DONE), cid(8052), disp(0)
1w5d: sess_appl: Invalid event ID ev(37), cid(8052), disp(0)
1w5d: cc_api_call_connected(vdbPtr=0x157B7AC, callID=0x1F74)
1w5d: sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(8052), disp(0)
1w5d: cid(8052)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED)
oldst(SSA_CS_CALL_SETTING)cfid(2943)csize(0)in(0)fDest(0)
1w5d: -cid2(8051)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_ALERT)
1w5d: ccCallConnect (callID=0x1F73)
1w5d: ssaFlushPeerTagQueue cid(8051) peer list: tag(4) called number (100) tag(2) called number (100) tag(1) called number (100)
1w5d: cc_api_call_feature: (vdbPtr=0x157B7AC, callID=0x1F74,feature_ind.type=1
1w5d: sess_appl: ev(27=CC_EV_CALL_FEATURE), cid(8052), disp(0)
1w5d: sess_appl: Invalid event ID ev(27), cid(8052), disp(0)
1w5d: cc_api_call_disconnected(vdbPtr=0x157B7AC, callID=0x1F74, cause=0x10)
1w5d: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(8052), disp(0)
1w5d: cid(8052)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(2943)csize(0)in(0)fDest(0)
1w5d: -cid2(8051)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCING_ALERT)
1w5d: ssa: Disconnected cid(8052) state(5) cause(0x10)
1w5d: ccConferenceDestroy (confID=0xB7F, tag=0x0)
1w5d: cc_api_bridge_drop_done (confID=0xB7F, srcIF=0x1779554, srcCallID=0x1F73,
dstCallID=0x1F74, disposition=0 tag=0x0)
1w5d: cc_api_bridge_drop_done (confID=0xB7F, srcIF=0x157B7AC, srcCallID=0x1F74,dstCallID=0x1F73, disposition=0 tag=0x0)
1w5d: sess_appl: ev(29=CC_EV_CONF_DESTROY_DONE), cid(8051), disp(0)
1w5d: cid(8051)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(2943)csize(0)in(1)fDest(1)
1w5d: -cid2(8052)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_ACTIVE)
1w5d: ccCallDisconnect (callID=0x1F73, cause=0x10 tag=0x0)
1w5d: ccCallDisconnect (callID=0x1F74, cause=0x10 tag=0x0)
1w5d: cc_api_call_disconnect_done(vdbPtr=0x1779554, callID=0x1F73, disp=0, tag=0x0)
1w5d: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(8051), disp(0)
1w5d: cid(8051)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(0)in(1)fDest(1)
1w5d: -cid2(8052)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_ACTIVE)
1w5d: cc_api_call_feature: (vdbPtr=0x157B7AC, callID=0x1F74,feature_ind.type=5
1w5d: cc_api_call_disconnect_done(vdbPtr=0x157B7AC, callID=0x1F74, disp=0, tag=0x0)
1w5d: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(8052), disp(0)
1w5d: cid(8052)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_ACTIVE)cfid(-1)csize(1)in(0)fDest(0)
If I use a local extension from PBX instead of DID (DISA) never have a problem...
I´ll apreciate any help.
LN
1 REPLY
Re: MC3810 Fax Problems
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
92
