MC3810 VoFr Fragments Dropped
have a MC3810 Network with mc3810-a2isv5-mz.120-7.XK1.bin, VoFr
When I Checked at Central Site Frame Relay Frag
I receive this
interface dlci frag-type frag-size in-frag out-frag dropped-fr
ag
Serial0.9 101 VoFR-cisco 80 12553 21233 0
Serial0.1 102 VoFR-cisco 80 506 505 0
Serial0.11 103 VoFR-cisco 80 74803 87891 12
Serial0.13 104 VoFR-cisco 80 91 505 0
Serial0.3 105 VoFR-cisco 80 503 503 0
Serial0.5 106 VoFR-cisco 80 3593 3603 0
Serial0.7 107 VoFR-cisco 80 2006 941 0
Serial0.441 441 VoFR-cisco 80 414 691 0
No errors on Serial 0
Serial0 is up, line protocol is up
Hardware is PQUICC Serial
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
reliability 255/255, txload 28/255, rxload 15/255
Encapsulation FRAME-RELAY, crc 16, loopback not set
Keepalive set (10 sec)
Scramble enabled
LMI enq sent 203, LMI stat recvd 203, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 4398/0, interface broadcasts 439
8
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:33:57
Queueing strategy: dual fifo
Output queue: high size/max/dropped 0/2048/0
Output queue 0/1024, 0 drops; input queue 0/75, 0 drops
5 minute input rate 32000 bits/sec, 44 packets/sec
5 minute output rate 57000 bits/sec, 119 packets/sec
176154 packets input, 10091994 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
210583 packets output, 12226692 bytes, 0 underruns
0 carrier transitions
This command do not reports any dropped packets
Interfruver-Corpo#sh frame-relay vofr se 0 103
VoFR Configuration for interface Serial0.11
dlci vofr-type cid cid-type input-pkts output-pkts dropped-pkts
103 VoFR cisco 4 data 81072 0 0
103 VoFR cisco 5 voice call-contro 442 441 0
512k and 6 remote 64k sites
At DLCI 103 remote end
Dropeed Fragments are increasing when transfering data ....
This is the only remote site that happends...
(64k)
Any help?
LN
1 REPLY
Re: MC3810 VoFr Fragments Dropped
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
102
