Bronze
MCS 7800, add harddrive??
CCM4.13, MCS7800 which is HP DL320 G2
I just upgraded from 1.0GB memory to 2.0GB memory.
When I open the box, I figured that there is only 1 Harddrive (40.G).
Can I add exact same size (I knew the part number that I can order from HP), and make RAID 0.
My question is that do I still get support from Cisco Tac??
Anyone done that before??
Thanks a lot!!
Ken
My question
Bronze
Re: MCS 7800, add harddrive??
It can be done but not without hassle. The problem is cisco image creates hidden HP patrition that will not get mirrored using Microsoft volume mirroring. Under Disk Management it shows as Unknown.
I was able to mirror the working volume C but not D. And if I want to boot from the second drive I had to use floppy disk with modified boot.ini. It would not boot any other way because of the missing HP partition.
You can use Ghost. Even thou it is not supported by cisco it works just fine. Problem is you would have to ghost it every time there is a major change.
A better idea is to get cisco-certified HP DL380 that supports hardware RAID 0. You can keep subscriber on 320 because subs are much easier to recover than publishers. I would highly recommend moving publisher to DL380.
Bronze
Thanks for reply,
Can we use HP software that install in CallManager server to do the disk mirror??
Change to new DL 380 is not the option for me. :(
Ken
Bronze
I'm not aware of any software (including HP) that will do proper software mirror. In any case no software mirroring is supported by cisco on DL 320.
Community Member
Got back from Cisco Tac... have to rebuid CCM to make the mirror to work.
Ken
179
