MCS-7815 redundancy
Would you tell me about the MCS-7815.
Is it possible to set MCS-7815 as the subscriber@in the cluster whose 7835 is set as the publisher?
Kind regards
Re: MCS-7815 redundancy
Yes of course.
As long as the server is capable of running CallManager (which the 7815 is) you can assign it whatever role you choose.
The difference between the 7815 and 7835's are the amount of devices that can be registered to them.
Gary
The 7815 is limited to 200 phones max. and since as a subscriber it gets its database from the publisher then the 7835 would need to be limited to 200 as well.
Thank you for your help.
121
