01-15-2002 08:19 AM - edited 03-12-2019 02:02 PM
Is there a way to configure the MCS-7835 in such way that the F1-key does not need to be pressed each time a restart is ordered?
I've looked in the bios config but could not find a way to disble the F1-key during restart/boot.
01-15-2002 08:45 AM
You need to upgrade the BIOS on the MCS-7835.
We are running the BIOS labelled "7835-BIOS-04-02-01.exe" and do not have to press F1 during the boot up process.
01-15-2002 01:04 PM
Why is it asking you to press f1? Do you know have both power supplies pulled in? If this is a lab then you can go into the BIOS and turn the off. You have to go to the advanced options and then it is near the bottom. I don't remember the exact key sequence it has been a while. If you can't figure it out I will go in the lab and see what it is. If this is production system plug in the other power supply.
Hope this helps,
-Mckee
01-16-2002 09:27 AM
Indeed this is a lab system and the second power supply is not plugged in.
I'll have a look in the BIOS to disable it and see if the restart works.
Thanks for the help.
Geert.
01-17-2002 07:50 AM
That sounds good to me. Did you find the place in the BIOS to turn it off?
Thank you,
-Mckee
