MCS Clustering
I would like to understand if there are drawbacks in using different MCS platform in the same Call Manager Cluster. For example a MCS 7835 together with a MCS 7825.
Thanks and regards
1 REPLY
Re: MCS Clustering
Not really, but I would recommend making the higher powered machine the publisher. Typically then you would register your phones to the subscriber(s). Then if a failover occurs they would fail over to the publisher.
157
СоздатьДля создания публикации, пожалуйста в систему
